Wolverine & Warrior
Old Mar 17, 2002 | 07:03 PM
Jeepwaco's Avatar
I heard that a Wolverine(with a few mod) can keep up with a warrior??!! what do you think??[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Mar 17, 2002 | 08:08 PM
thunderpower's Avatar
doesnt the wolverine have 6 gears? the warrior has 6 gears too! whoops...
Sounds about right. Get a pipe and filter.
Old Mar 17, 2002 | 08:29 PM
chad400ex's Avatar
The wolverine can keep up with a warrior if you are trail riding. It will actually out-perform a warrior in the woods. BUT...it is shaft drive, which means it is limited by it's rev limiter. The warrior can be re-geared, and will definitely pull away from you on any long/straight stretches. I had a 98 Wolverine with pipe, filter, jetting, etc..., and the only way to get it to go faster is to put taller tires on it. After that, you will lose some bottom end. This can be compensated for by putting in a cam and 11:1 piston. If you've got enough money to throw around, the wolverine can be turned into a pretty much unstoppable bike.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
