Wolverine & Warrior
The wolverine can keep up with a warrior if you are trail riding. It will actually out-perform a warrior in the woods. BUT...it is shaft drive, which means it is limited by it's rev limiter. The warrior can be re-geared, and will definitely pull away from you on any long/straight stretches. I had a 98 Wolverine with pipe, filter, jetting, etc..., and the only way to get it to go faster is to put taller tires on it. After that, you will lose some bottom end. This can be compensated for by putting in a cam and 11:1 piston. If you've got enough money to throw around, the wolverine can be turned into a pretty much unstoppable bike.
