AWD Problem Solved . . . sort of
Old Feb 23, 2000 | 12:47 PM
Loyal's Avatar
Some time ago I posted a problem I had with the AWD on my 96 Xplorer 400.
Recap:
- no AWD in reverse
- indicator light on pod indicating N when in R
- AWD in Hi and Lo when the bike felt like it
- AWD light on button would flick on and off
Solution (I think)
- a $119 (canadian) switch that ran from the rear of the shifter box to the circuit board. It looks similar to a toggle switch with a long bunch of wires connected to it.
The bike was ok in the dealers yard and on a short 5 mile run, but last weekend it started acting up again. The dealer also mentioned something about (1) a wire connecting to the front hub that brealk and (2) possible magnet problems in the front hub.
Any ideas ?
Loyal
Old Feb 23, 2000 | 05:27 PM
wgr's Avatar
wgr
Try isolateing the problem with a wiring diagram and a multimeter,start at the wheel and work your way back.
Old Feb 24, 2000 | 03:31 AM
Jaime's Avatar
That switch cost me 35 dollars and is easy to replace common problem with that shifter type the spring probably broke in the toggle or you broke the wires on the strut that energizes the magnetic coils on the hubs easy fix
Old Feb 24, 2000 | 12:25 PM
mudmachine's Avatar
Im not sure.. but wouldn't bypassing the override solve some of these problems... My VERY abused Scrambler finally started having an intermittent problem of the AWD kicking out and the lights lighting up all weird...
After bypassing the reverse rev limiter and the AWD lockout.. iTs been perfect....
The only bad thing is that when I shift to neutral or reverse.. the reverse light is on... When I shift to forward, the light goes out... so its really not a problem to me..
I would look into bypassing it... It is easy to do... just remember that when you do this, if anybody else rides your machine... fore-warn them that it has full power and reverse without the use of the override button...
Old Feb 24, 2000 | 12:29 PM
Loyal's Avatar
I was actually going to look into that MudMachine. I have the printout from Jacks site and may attempt it sometime soon.
thanks
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Sandman2.0
Jul 21, 2015 09:03 AM
ghost civic
Jul 19, 2015 10:13 AM
