SHIFT SHAFT PROBLEMS
Old Mar 21, 2002 | 10:16 PM
BlasterWhodi's Avatar
OK, a while ago, on my Blaster, the chain slipped off the front sprocket, hit the shift shaft, and cracked my case. I got the case welded but my shift shaft is still bent down. Is there any possible way I can bend it back without taking it out of the case and without breaking any tranny parts or the case?
Old Mar 21, 2002 | 10:29 PM
lonestarbanshee's Avatar
You will have to take your clutch cover off. After that, the clutches and basket come out, then the shift cam is right below. If the shaft is bent, you will have a hard time getting it through the cases.
Old Mar 21, 2002 | 10:33 PM
So I don't have to split the cases? All I have to do is pull off the right-side cover, take out the clutch, then take out the shaft?
Cole Hadden
Jun 15, 2025 09:05 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
tporath
Jul 11, 2015 12:31 PM
