Fox Strut Installation Help Needed
Old Mar 26, 2002 | 08:37 PM
Fasterthangas's Avatar
Hi! Guys.
I'm installing the Fox struts from Polaris on my '99 Scrambler 500. It has the long travel front end. Upon disassembling the first stock Sachs strut; I noticed that the shaft threads on the Sachs are larger than the Fox strut threads. As you may know; there is a special nut/spacer that holds the spring down onto the strut. I cannot use this nut now that the Fox strut shafts are smaller diameter than the Sachs. What has anyone here done in this situation?
I'm betting that this nut is a factory item only. Thanks!
Old Mar 26, 2002 | 11:00 PM
BarelyLegal's Avatar
Dude, I don't have an answer on the struts, but dang, your 400 looks WAY different. Lots of work in that machine.
Where did you get the swingarm? Looks pretty good. Are you sure there isn't anything else you can take off that quad? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 27, 2002 | 12:53 AM
Barelylegal;
Thanks! She weighs in at 320 lbs. now. The bike now sports Polaris Freedom Series plastic and custom seat. It also runs on nitrous instead of alcohol now. The swingarm is a custom chromoly piece by AZ Bad Boys.
http://pub8.bravenet.com/forum/show....rnum=612682403
Old Mar 28, 2002 | 02:58 AM
Cool. How much weight did the swingarm save? I'll try to hit them up for something.
So you run pump gas and Nitros now?
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
WilliamBos
Sep 30, 2015 08:08 AM
txkevin
Sep 21, 2015 02:02 PM
bonanza 440
Jun 26, 2015 10:01 PM
