Who makes a bigbore kit for a Warrior?
Does anyone sell a bigbore kit for a warrior? I'm not to sure i want to stroke the motor due to increased cylinder wear and durability issues. is there a larger sleeve available?From who? Thanx in advance
You can go a little bigger without stroking, but not much.
This is because to go bigger than 85mm bore requires resleeving and machining the cases, The only piston kits that I've found bigger than that are designed to be use with a stroker kit, and so have a different wrist pin to deck height. Because of that you won't be able to use them without stroking.
