Who makes a bigbore kit for a Warrior?
Old Mar 27, 2002 | 10:27 PM
sbucks's Avatar
Does anyone sell a bigbore kit for a warrior? I'm not to sure i want to stroke the motor due to increased cylinder wear and durability issues. is there a larger sleeve available?From who? Thanx in advance
Old Mar 27, 2002 | 10:42 PM
thenewfiebullet's Avatar
You can go a little bigger without stroking, but not much.
This is because to go bigger than 85mm bore requires resleeving and machining the cases, The only piston kits that I've found bigger than that are designed to be use with a stroker kit, and so have a different wrist pin to deck height. Because of that you won't be able to use them without stroking.
Old Mar 27, 2002 | 11:25 PM
ChevyGuy's Avatar
Fourstroke Tech makes big bore kits for the warrior
Old Mar 28, 2002 | 11:19 AM
Try these links
Four Stroke Tech
Powroll
They both offer stuff for the Warrior.
Old Mar 28, 2002 | 08:41 PM
dominatingwarrior's Avatar
Trinity makes big bore kits also. I've heard that stroker kits are more reliable than having it bored out.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 16, 2015 10:29 PM
