mojave hitting rev limiter?
Old Mar 31, 2002 | 10:11 PM
Grizzwald's Avatar
Just started modifying my 2001 Mojave. This weekend I installed a White Brother E-series silencer and replaced the airbox with a K&N clamp on filter. The carb has been rejetted with the largest main jet included with the Dynojet kit (134). It seems to run great through the gears. However, it starts to stumble at full throttle in 5th around 60mph. Is it possible that I'm bouncing off of the rev limiter?
Old Apr 1, 2002 | 08:33 AM
2000MOJAVE's Avatar
Yes, it is possable and you probably are hitting the rev limiter. Mine did the same thing when I had an after market exhaust on it. It actually reved so much faster that I would hit the rev limit going through the gears once in a while until I got used to it, but like you said, on long straight aways in 5th gear it would eventually cut out. Try a 13 tooth front sprocket, you will gain quite a bit more top end speed and with your mods you won't even notice the the difference in the bottom end.
Old Apr 1, 2002 | 11:19 AM
stebob's Avatar
Well Grizz, you should run the machine 'till it does this and then shut if off and pull the plug. I think you could be running lean when WFO, since your using a clamp on and the 134 is what they recommend for stock air box. If the plug is white then it's a lean condition, should be tan like a grocery bag. Just a thought, any other opinions?
Old Apr 1, 2002 | 12:01 PM
gaff's Avatar
I was thinking the same thing stebob. Running into a rev limiter is a very distinc sound of braeking up thow, it's hard to confuse the two.
The larger counter sprocket and bigger main probably is a must. You can get a steel counter sprocket for $6.99 and the mains from dynojet are $2.50 a piece, I just got 3 and it was 10.50 wich included shipping.
Old Apr 2, 2002 | 08:02 PM
mentalmojave's Avatar
I have a uni 2 stage clamp on filter and 18 discs on mine and the only way My plug don't turn black is with a 132 dj my friend gave me and my needle on the 3rd clip with a shim under it and my fuel level at 16mm.
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
black_thunder
Sep 22, 2015 07:59 PM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
