flip fron wheels ?
Old Apr 1, 2002 | 11:53 AM
juststout's Avatar
if i were to flip the front wheels on my warrior what would it do ?
and how would i go about doing that?
Old Apr 1, 2002 | 12:19 PM
ChevyGuy's Avatar
If you flipped then it would make your front end wider and more stable.
On my warrior I had to drill new holes on the other side of the rim because the valve stem hit my brake caliper. So I put a new valve stem on it and put one in backwards where the old one is.
Old Apr 1, 2002 | 12:21 PM
pcbanshee's Avatar
You can't flip the front wheels because the valve stems will hit the brake calipers. You can take your old valve stems out then put valve stems in backwards in your origional holes. Then drill a hole in the other side of your rim and put a new valve stem in. I wouldn't do this though because your rims would look ugly and you can't return it to stock later. Just get wheel spacers.
Old Apr 1, 2002 | 08:00 PM
KJMAXXX's Avatar
Dont drill holes.
Get flush mount valve stems
Just install these and reverse.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
