Sport Quads Discussions on sport quads.
Shock Adjustment
Old Apr 2, 2002 | 03:56 PM
EeEcksRider's Avatar
For a rear shock adjustment, when the back wheels have a tendancy to bounce and smack the seat against your butt, does that mean the rear compression is too stiff, or the rebound is tighter than a snakes pu**y?
Also, if the back end rips back and forth, left right during the whoops, same question, compression or rebound?
Old Apr 3, 2002 | 02:24 AM
Pandemonium's Avatar
If you have never set the rear spring and you are out of the manufacturers 150-180lbs ideal weight, then you will need to adjust it. When adjusting rebound and compression, start on a familiar course with both set full. With each lap or two, back them out a click at a time, until you find a comfortable setting for your riding style. Your problem could be either, so spend the time to set it properly.
Old Apr 4, 2002 | 12:31 PM
YZGUY's Avatar
See http://off-road.com/atv/suspension/shockadj.htm I would suggest starting from scratch!
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
