250R SHIFTING PROBLEM.. HELP!!!
Old Apr 2, 2002 | 09:55 PM
lonestarbanshee's Avatar
I got the R back in one peice yesterday, and took it for a spin. Everything worked for me then, but today, when I got on it to put some more time on it, it had a big shifting problem.
Going down into 1st is not a problem. Going up to 2nd and on from there is. Mostly every time I hit the shifter to pull it up into another gear, it acts like its hitting neutral. Ex: 2nd-3rd, big miss right in the middle, then I hit the shifter again and it popped up into 3rd. It will go through all 6 gears, so I don't think its a problem in the transmission. Sometimes it will shift like it's supposed to, and sometimes it won't. The problem is REALLY annoying me.
If you guys think you know what it is, click HERE then go to SHIFT DRUM to see a ServiceHonda picture of the area that I THINK is the problem. Number 9, 12, and 14 are the culprit.. I THINK. I made 100% sure that the transmission and shift forks were done right, so I don't think that's the problem. When I disassembled the motor, the number 14(spring) was backwards, with the number 12 inside the shift drum. When I looked at the Clymer, it was different. The 12's were to the outside. So, I put them out, and now it won't shift correctly.
Do any of you have an idea what it could be? I HAVE TO HAVE THIS DONE BY TOMORROW NIGHT! Thanks for all your help.
Old Apr 2, 2002 | 10:10 PM
Ohio250rlover's Avatar
i don't have any useful tips but DAM lonestar do you have some polaris part's on that r or somethin u seem to have problems left and right
Old Apr 2, 2002 | 10:30 PM
ohio250Rlover.. Alot of problems? I've only ridden it four times.
Anybody with any pointers?
Old Apr 2, 2002 | 11:00 PM
yamracer's Avatar
When I redid the transmission on my R, I ordered all my gears and shift forks from service honda. Well on one of my shift forks there was a bur that wasnt let it fully engage or something like that. Luckily my mechanic caught it before we put it all back together but we had to use a dremil and buff that burr outta the shift fork. I dont know if this is what is happening in your case but it could be. I am not saying nothing bad about service honda though they have unbelievable service and prices. I still go through them on everything. Well I hope this helps some!
Old Apr 4, 2002 | 12:19 AM
kciH's Avatar
Did you get the dowel pin in the back of the shift star that bolts to the drum? It's just a tiny little piece.
Old Apr 4, 2002 | 01:45 PM
Thanks for the help. My 1st diagnosis proved to be true. One of the spring loaded flaps was turned sideways.
Good lord this thing is FAST!
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
