Trouble with Rear brake caliper
Old Apr 3, 2002 | 01:36 PM
BigDogX's Avatar
I bent my rear brake rotor, so when i took off the rotor someone decided to step on the brake pedal and push the caliper out further. Now the piston wont go back into the caliper, i figured just bleeding the system would work and pushing the pison back into the caliper, but it doesnt seem to want to budge. any help on what i should do or should i just push on the piston harder? thanks
Old Apr 3, 2002 | 02:31 PM
HondaMarshal2's Avatar
Make sure your e-brake adjustment screw is all the way loose. Next get a pair of challel locks and push the caliper back into the cylinder. You should not have to bleed the brakes. How bad was it bent?
Old Apr 3, 2002 | 02:49 PM
BigDogX's Avatar
I suppose i should tell what kind of quad i have, its a 250x with no e-brake. I will try the channel locks. Yeah it was bent pretty good, but i ordered a new one, everyone says to just bend it back, but i dont have the resources, and im not sure that anyone in town would be able to do it either, no sweat off my back anyway... thanks
Old Apr 3, 2002 | 03:15 PM
Good Luck Big Dog
Old Apr 3, 2002 | 04:36 PM
retro's Avatar
If the caliper pistons are pushed out too far use a large C-clamp to squeeze them back in. Just be careful not to wreck anything.
ERIC
Old Apr 3, 2002 | 04:47 PM
250rampage's Avatar
I've used a c-clamp, just take it slow, or you could blow out the seals in the caliper
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
