Reduce weight
Old Apr 9, 2002 | 03:20 PM
edge020's Avatar
Im trying to reduce the weight on my scrambler 500 4x4 alot. I wanna do this becasue i want big air on the dunes. Are there any suggestions as to what i could to to reduce or any as to what i could do to get bigger air and stay up for longer?
Old Apr 9, 2002 | 04:51 PM
Blazer250's Avatar
Cut off the floorboards, aluminum wheels, new pipe, clutch kit, remove battery, remove steel chain guard disc, lighter swingarm, remove skidplate, aluminum bumpers, lighter tires, lighter handlebars, drill out some un needed parts on frame, etc.
Old Apr 9, 2002 | 05:02 PM
edge020's Avatar
how much you think that will run?
Old Apr 9, 2002 | 05:09 PM
pudljumpr's Avatar
For all of those mods that blazer mentioned and maybe a few more he didn't, you're probably looking easily between $1,500 and $2,000. Tires and rims alone will get you to about $400, pipe, clutch kit, and silencer will cost about $475 all together, nerf bars bet $100-250, swing arm about $250-350, handlebars about $65, bumpers about $100-165....The list goes on. So you see, depending on what you feel for priorities and the "cosmetic touch" you want to add to your machine...better open your wallet.[img]i/expressions/face-icon-small-shocked.gif[/img]
00 scrambler 400 4x4 K&N
98 xplorer 400 K&N, boysen reeds, clutch spring
Old Apr 9, 2002 | 05:18 PM
edge020's Avatar
HOLY SHEOT thats not cheap. hahhaha thanx
Old Apr 9, 2002 | 05:21 PM
edge020's Avatar
how much weight you think that it will take off if i do all those? and will it still be good in the woods?
Old Apr 9, 2002 | 06:59 PM
Daransport's Avatar
My Sport is 387lbs!!! The floorboards, starter, starter bracket, air box, oil injector, bunch of plastic, replaced some metal in the swing arm with chromoly, and all brackets that aren't used are removed. I have aluminum rims, nerf bars, aluminum handle bars, chromoly steering stem, Krom-lite front bumper, aluminum foot pegs, and aluminum skid plate. I also added HPDs race pipe and silencer....big weight difference over stock!! My MX 400 Sport
Old Apr 9, 2002 | 07:25 PM
edge020's Avatar
So your sayin you took off almost 300 pds.?
Old Apr 9, 2002 | 07:49 PM
edge020's Avatar
hahah whoops i htough u said the sportsman 400
Old Apr 9, 2002 | 09:11 PM
modquad's Avatar
Just a thought, I could be wrong, but since you have a 4x4 Scrambler, there already is a few aluminum parts on your quad. Break out a magnet, and check the front bumpers (you can strip the powder-coating and polish them)the floorboards...but nerfs do look a whole lot better, and wheels. Not sure, but I think some of them came with some light rims....maybe that was just the "X" model. Another easy mod, if you are handy, or know a good fabricator, is changing out the lower trans mount to a 1/4" titanium unit. It's easy to remove for the pattern, and I think it was a savings around 3lbs. Hotseatperfomance.com has some pics of the nerf installation. Their's are spendier than fabbing the Banshee bars, but they look a whole lot nicer.
Good Luck,
Ken Thompson
