bogging effect when I get on the throttle
Old Apr 15, 2002 | 08:51 PM
mynewcannondale's Avatar
has anybody else had somewhat of a hesitation when you get on the gas? Haven't noticed it before. What could it be from? It might just be that I don't have the RPM's high enough. What do you guys think
Old Apr 15, 2002 | 08:53 PM
Alaska400EX's Avatar
I haven't noticed a bogging, but I did stall it out a few times trying to get rolling while it was still a bit cold.........JIM
Old Apr 15, 2002 | 09:09 PM
Ryanstones's Avatar
I would look at the air filter first. Then make sure you have the freeplay adjusted correctly on the throttle cable. Those little Orings on the fuel line quick connect can cause some weirdness too. If your revs weren't high enough it would have killed.
As you get hours on your 'dale it will get progressively easier to ride. At least on mine it has.
Old Apr 15, 2002 | 09:47 PM
briansgi's Avatar
Air restriction or fuel delivery problem. Make sure your air filter is good and clean and check or replace that o ring on the fuel line, also replace your fuel filter if it hasn't been done in over 5 hours.
Old Apr 15, 2002 | 11:38 PM
CornDog's Avatar
one time i thought mine was bogging but it was just my holeshots in the sand. holeshots really suck in the sand!
Old Apr 16, 2002 | 12:21 PM
Mxracer98's Avatar
The only time ive had trouble with my cannibal bogging was when I was ready to go ride jabbed the throttle a lil bit and you could here the engine sucking for air and it cut off and died, but I havent had that problem since then.
Old Apr 17, 2002 | 10:20 PM
briansgi's Avatar
Mynewcannondale, did you ever figure out what was causing your hesistation you were experiencing?
Old Apr 17, 2002 | 10:37 PM
not yet, I haven't had time to fix yet. in fact I don't even know if it is still doing it. I did take out the play in the throttle today, tomorrow when I get home from work I will do a full diagnoses (air filter, O ring, excetra) "forgive the spelling". Anyway I will find out tomorrow I will keep ya posted. By the way how long does it take to get a silencer, and a remap from R&S? "ballpark fig." I will be sending in my computer next week to get the remap to the moto.
Old Apr 17, 2002 | 10:40 PM
briansgi's Avatar
R&S turned my computer around in one day plus they had the HMF silencers in stock. Can't ask for any better service than that![img]i/expressions/face-icon-small-happy.gif[/img]
You might just call them to make sure they have the silencers in stock before you send off your computer.
Old Apr 17, 2002 | 10:44 PM
Thanks for the info and the very quick reply!
