cold starting?
Old Apr 18, 2002 | 12:23 AM
special's Avatar
I have to hit the start butin at least three or four times before it will crank the first time when the engin is not warm.Is there a cold start map?I seam to be fouling plugs because of this.
Old Apr 18, 2002 | 12:33 AM
Alaska400EX's Avatar
Yes, there is a cold starting map for download on Cannondale's website. My Speed already came with it...#282...but you can find the remap on the site......JIM
Old Apr 18, 2002 | 08:45 AM
briansgi's Avatar
3 or 4 times before it will crank or 3 or 4 times before it will start, big difference. Mine takes 2 - 3 hits with the starter when it's cold to start but it has never fouled a plug.
Old Apr 18, 2002 | 09:03 AM
special's Avatar
It will turn over fine.I just wont start up without letting the fuel pump prime 3 or 4 times.
Old Apr 18, 2002 | 09:10 AM
briansgi's Avatar
I'd take it in and let your dealer do all the updates and remaps and see if that helps. How does it start when the engine is warm?
Old Apr 18, 2002 | 09:15 AM
I might have misunderstood what you were saying. I agree that a few times of cranking before it starts cold seems to be normal, only because I don't sit there and crank it forever on the first push. I got a little addendum paper when I picked mine up and it went through specific procedures for cold starting the quad to avoid fouling plugs, so this must have been an issue owners were having. I haven't fouled one plug since I got it and I am up here in Alaska...the procedure seems to work........JIM
Old Apr 18, 2002 | 02:35 PM
trout's Avatar
alaska440, would it be possible for you to post htose starting instructions for him and others?
thanks,
Old Apr 18, 2002 | 06:38 PM
Cannitor's Avatar
took mine in to the shop today.........
they are downloading the stalling fix
they are downloading the cold start fix
they are downloading the speed remap
i'll keep you posted on the results....
Old Apr 18, 2002 | 07:27 PM
ATV Cold Starting
*Make sure the battery is fully charged. A low battery will turn engine over, but will fail to activate engine management circuits.
*Wait 5 seconds after pressing the engine start button the first time to activate or "wake up" the engine management circuits.
*Pull in the clutch lever ONLY when holding the start button down to turn engine over.
1.Position the vehicle on level ground and shift the transmission into neutral.
2.Turn the ignition switch to the ON position.
3.Switch the engine stop switch to RUN.
4.Quickly(1 second)press the engine start button and release it to activate the engine management circuits and WAIT 5 SECONDS. During this time the fuel pump turns on for 3 seconds then off to pressurize the injectors, the Idle Air Control Valve(IACV)will move into position opening the idle bypass port. If you don't wait 5 seconds, insufficient fuel pressure and incorrect idle air bypass positioning will prevent the engine from starting; resulting in spark plug fouling.
5.After waiting 5 SECONDS, pull in the clutch and press and hold the engine start button until the engine starts; but hold it NO MORE than 2 or 3 seconds at a time.
6.When the engine starts, slowly release the clutch lever.
7.Allow the engine to idle until it reaches operating temperature(70C)before you begin riding.
This is what I was given, hope it helps............JIM
Old Apr 18, 2002 | 08:28 PM
special's Avatar
I also just droped mine off at the dealer.They are going to remap it for cold starting,and staling.I will give an update when I get it back.
