ack! need help!
Old Apr 18, 2002 | 12:57 PM
98trailblazer's Avatar
ok, i got my chain off the wheeler, but how can i get the links out without a link pusher?
Old Apr 18, 2002 | 01:01 PM
warrior007's Avatar
I use a dremel with a cutting wheel or a bench grinder to grind off the nubs, then they will just push out pretty easily when you tap on them with a small bladed screwdriver or something similar.
Old Apr 18, 2002 | 01:04 PM
dont got one of those, will drilling them off work?
Old Apr 18, 2002 | 01:12 PM
warrior007's Avatar
might, but will be a pain in the *** if you dont have a drill press. the pins are hardened and you'll slip off. you only need to remove the part the is showing then tap them out.
Old Apr 18, 2002 | 01:41 PM
any one else know a fairly easy way without a grinder? what if i just cut the link off with a hacksaw? =P
Old Apr 18, 2002 | 02:06 PM
warrior007's Avatar
you'll still have to get the pin out so you can put the master link back in
Old Apr 18, 2002 | 02:09 PM
Surveyor's Avatar
in order of prefrence if I was going to separate a chain:
1) use the master link if it had one
2) chain breaker
3) bench grinder
4) dremel tool
5) rotary grinder on a drill
6) sharp file
if I did'nt have the tools, I'd take it somewhere..parts house, auto repair shop, motorcycle repair shop, lawn mower shop, friends house..etc...
any repair shop should have a grinder..too much work otherwise..
this will work for separating the chain..BTW don't they have master links in them..like a bike? if you are trying to take out a link, I understand it a lot better...you will have to separate it on the full link sideplate...the ones with both pins through the sides..CLP
Old Apr 18, 2002 | 02:16 PM
stebob's Avatar
Go drop 30-50 bucks and get you a Dremel tool. It will come in might handy for all kinds of projects. Definitely worth the investment.
Old Apr 18, 2002 | 05:43 PM
modquad's Avatar
Try your local dealer, or motorcycle shop. They'll probably do it for free, or at worst, a couple of bucks.
Ken Thompson
