Round Type Silencer Break in question
Old Apr 29, 2002 | 10:19 PM
CaliforniaCannibal's Avatar
Okay,
I've got the round type silencer with only about 10 hours on the machine. I've noticed a pronounced discoloration in the middle of the silencer. The middle third of the silencer has turned a rainbow blue/red, while the front and back thirds have remained bright silver. It's definitely a heat discoloration.
On the inside edge where the silencer is seamed, there's a little bit of black carbon residue that's seeping from the seam. It's not drastic but you can see it.
The bike doesn't seem quite as fast as when I first got it, but that might just be because I'm over the initial shock of how quick it is and I'm getting used to the acceleration. Definitely not a scientific assessment.
Have your silencers discolored in this manner, and does that sound like a split seam or just normal leakage when the muffler is seamed?
Old Apr 29, 2002 | 10:24 PM
Dex2380's Avatar
I have heard that the discoloration is normal, not sure if it is or if the whole pipe should do it?
As far as carbon build up you might want to purge the carbon out of the pipe (tells you how in the manual under the silencer section)
To find out if it is split, someone else on the forum said to splash some water on it like you would a tire with a hole in it. Do this right when you start it up as it will obviously evaporate if the pipe is scorching hot. This same person said you also might not be able to tell right away if the pipe is split.
Not sure if this helped, keep us updated.
-Josh
Old Apr 29, 2002 | 10:26 PM
smitty911's Avatar
Mine is doing the exact same thing. I was told that the injector offset needs to be done to get rid of the rich condition.
I only have about 10 hours on my bike, so I think it's time for the FMF and moto/blaze map. That will get rid of the blueing and alittle more power.
Smitty
Old Apr 30, 2002 | 09:11 AM
briansgi's Avatar
Every stock silencers I have seen including my 2 C'dales did the same thing.
Old Apr 30, 2002 | 11:25 AM
Dex2380's Avatar
right on smitty, are you gonna order the fmf that comes on the moto/blaze? do you know how much it runs $ ? can you use yoru same header?
-Josh
Old Apr 30, 2002 | 08:52 PM
smitty911's Avatar
I spoke to Knowsalot today and asked him, but he hasn't seen a moto to be able to tell. Time for a part number track down.
I'll have Trinity do the re-map, and find out about their slip on.
Smitty
mtdewmn
Jan 19, 2017 12:13 PM
toonces
Jul 31, 2015 09:27 AM
Captjay
Jul 23, 2015 12:33 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
