700 Air Box Stuff
Old May 4, 2002 | 09:04 AM
SpruceDuece's Avatar
I gave my 700 a real good cleaning last night, and found 2 things that concerned me. First of all I am not getting any fuel mileage. Last weekend I rode 36 miles and used 4.5 gallons of gas. It has been suggested that I have the dealer check the fuel pressure as it may be dumping fuel. I am having that done this week. What concerned me was that there was liquid in the tube under the air box. It wasn?t full, but had a good inch and a half of something in it. When I pulled the plug this stuff smelled just like gas. I have not been in any really deep mud or water, but have splashed through some. The prefilter had some sludge on it, and I have never heard it backfire. Any thoughts would be appreciated.
Thanks,
SpruceDeuce
Old May 4, 2002 | 09:27 AM
McDrifter's Avatar
If your getting enough blow back to saturate your air filter enough to drop out into your airbox. I would say your onto something, with the amount of air going through your air filter I would believe that most of the gas that gets on your filter would evaporate not drop out into your airbox. As well, if your only getting 36-38 miles per tank and my Spruce 700 is getting 70-75 miles per tank it could be possible that half your gas is blowing back into your airbox ( most evaporating on the airfilter and some dropping out into your airbox ). These are just my early morning thoughts I could be out in left field hear lol.
Old May 4, 2002 | 09:44 AM
polrider's Avatar
If it is brand new it needs about 100 good miles to see better gas milage. At least thats what happened with mine.
Old May 4, 2002 | 12:00 PM
Polarisman3210's Avatar
Same thing happened to my Magnum a while back, I found what looked and smelled like a gas/oil combo. I cleaned it out and never had the problem again, and I have no Idea what caused it, but it hasn't done it again since. But if this tells you anything, the machine was brand new when I discovered it. So maybe after breakin, it won't do it.
ReconBayou
Oct 31, 2022 05:37 PM
fd24
Jan 16, 2019 08:59 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
bigred20653
Oct 2, 2015 10:05 AM
kampswas
Sep 23, 2015 05:05 AM
