97 Foreman problem
Old May 7, 2002 | 10:24 AM
sean97's Avatar
Hello All, I just joined here and just wanted to say that this website is great, being a atv enthusiast, it has alot of good information.
I have a 97 Honda Foreman, this bike has been great so far, until now,
the last time I was riding it, it was running good, I was going down the trail and it just acted like it ran out of gas, came to a stop, got it running again and managed to get back to the truck, it will run at idle but as soon as you give it gas it wants to die, no it's not the choke, I've tried that, in fact it seems to run better with it on, but it still won't go full throttle. I checked all the fuses, purged the spark arrestor, changed the spark plug and nothing....
any help is appreciated
Old May 7, 2002 | 11:13 AM
canadianmudrunner's Avatar
I have the same problem with my recon.The thing just dies for no reason.You give it gas and it pops and dies.I think its something to do with the carb.
Old May 7, 2002 | 07:09 PM
Honda19's Avatar
Sounds like water in the carb to me. Thats what happened to mine last fall. It easy to fix though...just take it apart and blow the water out of it.
Old May 7, 2002 | 07:20 PM
250rampage's Avatar
Sounds exactilly like water in the carb. on the side of the carb, toward the bottom, there should be a screw that drains the float bowl. Shut the gas off at the petcock, and open the screw. Gas will drain out the carb overflow tube. Close it up, turn the gas back on, and crank it till it starts (let off every 5 sec's for so to avoid burning up the starter). It'll take longer to start because the carb will be dry at first. After this your problem should be gone.
Old May 8, 2002 | 07:42 AM
Knucklehead's Avatar
When I had my 350 Fourtrax 4x4, this was a symptom of when I needed a new spark plug. The funny thing was is that it worked fine up until it would just die under throttle and barely idle on it's own. The first time this happened to me I was baffled for two days until I tried a new plug and it started right up. Regardless of when you changed it last, it wouldn't hurt to put in a new new one anyway.
Old May 8, 2002 | 09:59 AM
sean97's Avatar
Thanks for all your help guys, I got it running last night, I blew the fuel line out and it runs great now, guess I'll have to go riding this weekend...
thanks again..
p.s. if all you guys were closer I'd buy ya'll beeeeerssss.
greg74
Sep 10, 2019 03:03 PM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
