the polaris that just won't spark (I really need help with this)
Old May 8, 2002 | 01:41 AM
liteweb's Avatar
I own a 93 Polaris trailblazer 2x4. I've driven the hell out of this thing for years without any problems whatsoever. But recently, out of nowhere, the thing just stopped sparking. This is a very frustrating problem. Right now it is sitting in my garage, rotting away, just because it won't spark!
Here's the down low...
I have tried replacing the CDI ignition module, the coil, the spark plug cable, and the rotor magnets with no resolve (pretty much the entire ignition system)
If anyone here has any ideas what else could be causing my quad not to fire up, PLEASE drop me a line. My email address is trent@liteweb.net.
Any help will be greatly**** appreciated.
Thank you for your time!!
Trent Hopkins
trent@liteweb.net
Old May 8, 2002 | 04:38 PM
thud's Avatar
Im not at all familiar with Trailblazers so im just wondering if it has a kill/deadman switch somewhere on it? If it does its possible that the wiring harness or the switch itself is bad. Seeing as youve replaced essentially the entire ignition system the problem must be somewhere else. I know on my AC if i bump the kill switch all the lights work etc it just wont turn over,which results in a really dumb feeling when i realize why it wouldnt start LOL
Old May 8, 2002 | 11:24 PM
RickRitter's Avatar
I think your primary (source ) coil is out . It is the most common electronic failure . $42 will fix it .
I wish I had the part number with me , I would post it .
Old May 9, 2002 | 10:41 PM
Conkster's Avatar
The same thing happend on my TB one minute it was running then i hit a big water hole then it shut off and lost all of it's spark It turned out to be the wire for the kill switch got wet and it wouldn't get spark. Just try to unplug the wire and see if that gives you spark if it does then i would say that it's either the wire just got wet or the switch is bad.
Old May 9, 2002 | 10:47 PM
mudstomper's Avatar
ye sit should be the kill switch or connection. did that year let you start in gear? if not check that saftey switch as well. [img]i/expressions/face-icon-small-happy.gif[/img]
Jmuddin284
Jan 19, 2026 07:16 AM
Coryco
Jul 6, 2015 07:30 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
D-Hagz
Jul 4, 2015 02:19 AM
