HUB FLUID
Old May 10, 2002 | 11:33 AM
jtrundle's Avatar
IS AUTOMATIC TRANNY FLUID TYPE F GOOD ENOUGH FOR SCRAMBLER 4X4 HUBS? HAS ANYONE USED THIS OR SHOULD I USE A POLARIS FLUID?
Old May 10, 2002 | 11:49 AM
SP500HOBumblebee's Avatar
I just use the Polaris Fluid it is only $2.99 a bottle. I don't feel the risk is worth it. My $.02.
Old May 10, 2002 | 01:42 PM
AlkyBurninX's Avatar
Good ol' type F is all my polaris has ever seen. Back when it was made, polaris didn't offer a hub fluid. After seizing a bearing at about 60 mph and being slung sideways on the road, I started routinely repacking my front wheel bearings. Everytime I did this, I would change the hub fluid. I never found any shavings or other signs of wear. The hubs also always worked properly. I can bet my bike has seen more abuse than most. Plus it is piped, ported, and other mods. However, I do only run polaris engine oil, and if hub oil is only 2.99 a bottle that might be the way to go.
Old May 10, 2002 | 04:45 PM
SnowDrift's Avatar
I used Polaris oil when I first got mine, but it gave me trouble - hubs sticking when disengaged. I switched to Mobil 1 synthetic ATF and have had no trouble since then.
I had a buddy that had horrible trouble with his sportsman and he did the same and hasn't had trouble since then.
Polaris oil around here is $5.00/bottle - expensive for no more than you get.
SnowDrift
Old May 10, 2002 | 04:56 PM
jtrundle's Avatar
Thanks for all the info , guys. I think I'll go with the synthetic Mobil1 ATF as well. The closest Polaris dealer to me is about 50 miles. I appreciate all the input.
Jimmy
Old May 10, 2002 | 05:28 PM
mudstomper's Avatar
Hi Guys, are we talking about the front diff or hubs? I have a sportsman 700 and had the wheels off and did not see a place for oil maybe take the bearing out to repack but fluid where? please let me know I was in a hurry and did not notice thanks for your help.[img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old May 10, 2002 | 05:31 PM
jtrundle's Avatar
My atv is a 97 scrammy 400 4x4. We are talking about the hubs. On my atv, on the hub there is a little screw on the hub about an inch back from the end. I don't know if the sportsman is like that or not.
Old May 11, 2002 | 01:10 PM
PolarisPower500's Avatar
The 700 does not have hub fluid.
I have used a generic brand Type F for a few months now in my Scrambler, and the hubs have never worked better. When I first bought it (used-several months ago) I would get sticking hubs and have to back up to disengauge one or both. Now with the Tyep F, When I hit a mud hole both front wheels go and when I come out both front wheels are disengauged just as quickly as they engauged.
Old May 11, 2002 | 07:11 PM
hodaddy's Avatar
i started out with polaris hub oil on my sportsman 500 but had problems with the 4 wheel drive also switched to ford f type transmission fluid and never have had any more problems
Old May 11, 2002 | 10:52 PM
SnowDrift's Avatar
I am disappointed to say that I had a hub stick again today after changing to Mobil 1 ATF. What is the deal with the type F fluid over Dextron? I don't own Fords, so I have never had any on hand, but if there is a reason to have it over the Dextron for the hubs, then I will be all for it.
Any comments?
SnowDrift
