Wheel Spacers??
Old Mar 3, 2000 | 06:32 PM
letitsnow's Avatar
What does everyone think about using DuraBlue front wheel spacers. Are the stock hubs strong enough to handle these? I don't race and rarely catch more than 10 feet of air.
Old Mar 5, 2000 | 01:25 PM
letitsnow's Avatar
Hasn't anyone used wheel spacers before?
Old Mar 6, 2000 | 05:12 PM
sAyIt_fmf's Avatar
Nope never bought wheel spacers.....Ended up changing the front end instead...
I have heard of the spacers stressing the stock parts...but never tried them....
Another alternative is to get offset rims...they will make the wheeler wider, without gaining the weight of the spacers.(which is prolly next to nothing anyway)
Old Mar 10, 2000 | 07:10 PM
Sickman's Avatar
If you want to be able to turn, I wouldn't spend the money on spacers. When you widen the front end that way, you change the steering by moving the wheel away from the center line of the spindle. when you do that any bumps you hit will be more magnified and it will also push more in corners. It may seem like a cheap upgrade at the time, but wider a-arms are the way to go even over off set rims also. I feel the same way about rear wheel spacers, instead of spending $50 on spacers, you might-as-well save up for an adjustible, lifetime warranty axle. Reason being, is that you overly stress the stock axle with spacers and it will bend much easier, especially if you race (Which is the only time people want the rear wider anyway) you bump tires, land hard off jumps, and maybe crash once-in-awhile, and your bound to bend an axle. Personally every aftermarket axle I have owned I have bent just landing off the big jumps I do, but they are fixed for very little (Unless you buy a DuraBlue and they pro-rate the cost after the first axle, thus no real liftime warranty; I stick with Lonestar or RPM now)...
Hope this helps,
Sickman
Old Mar 10, 2000 | 10:26 PM
letitsnow's Avatar
Thanx Sickman....
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
