Reeds on a 2 stroke
Old May 16, 2002 | 10:42 PM
carjocky5150's Avatar
How do you change them. They are located under the carb correct? My sons 90cc quad needs the reeds changed and I figure with a little help I can do it. Any suggestions on how to do it??
THANKS!!!
Old May 17, 2002 | 03:22 AM
redrider707's Avatar
how do you know that it needs reeds its a 01 i cant see it needing reeds yet . but to do it just pull the carb off should be 4 bolts pull them out and clean the old gasket off and replace reeds new gaskets are a must put them on dry (no silcone) run the bolts in tighten down put carb back on and good to go . hope i helped
Old May 17, 2002 | 09:32 AM
<< how do you know that it needs reeds its a 01 i cant see it needing reeds yet . hope i helped >>
I agree but the dealer said they are having problems with them and the symptoms I described he said sounds like the reeds. Thanks for the help!
Old Jun 16, 2002 | 05:13 PM
raptor720's Avatar
What are the problems that you mentioned to the dealer?
exmotocrosser
Sep 13, 2019 06:12 AM
QuadRiders
Oct 22, 2015 04:13 PM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
