Reeds on a 2 stroke
how do you know that it needs reeds its a 01 i cant see it needing reeds yet . but to do it just pull the carb off should be 4 bolts pull them out and clean the old gasket off and replace reeds new gaskets are a must put them on dry (no silcone) run the bolts in tighten down put carb back on and good to go . hope i helped
<< how do you know that it needs reeds its a 01 i cant see it needing reeds yet . hope i helped >>
I agree but the dealer said they are having problems with them and the symptoms I described he said sounds like the reeds. Thanks for the help!
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
