Special socket for Cylinder on Scram 400?
Old May 20, 2002 | 03:46 AM
BayouBlaster's Avatar
Can Anyone tell me what kind of special socket or wrench that I need to use to tighten and torque the cylinder back on to my 2000 Scram 400 in addition to the torque wrench? Those nuts are located in a very tight spot height wise and I couldn't get any of the sockets in my tool chest to fit on them and unscrew them without the aid of a knuckle. I didn't think that you could use a knuckle with a torque wrench and get the correct torque(if I'm wrong about that, let me know). Thanks again.
Old May 20, 2002 | 06:57 AM
Mike Chero's Avatar
BayouBlaster,
The best thing to use on these nuts is what is commonly called "Crow's Feet". They are a small open end wrench with a small square hole for a torque wrench machined into them. Tighten the bolts up in a cross pattern with a regular wrench then, using a torque wrench in the square hole in the crows feet, tighten the bolts to spec. Just about any good hardware store should have them.
Old May 20, 2002 | 08:27 AM
Farmr123's Avatar
I know it isn't very scientific, but what I did on my Xplorer is torque the bolts I could get to with the torque wrench, and then tighten the other with just a box wrench, so it 'felt' as tight as the other. I managed to get a socket & torque wrench on 3 of the bolts. All I can say is, I was careful, and it worked. If you plan on doing that a lot, I would buy the proper wrenches, though.
Farmr
Old May 20, 2002 | 03:29 PM
modquad's Avatar
No matter which tool you use, be sure to retorque the fasteners again once the machine has been thoroughly warmed up. This helps to re-seat the cylinder.
Ken
Old May 20, 2002 | 07:38 PM
powerslider's Avatar
I use a Snap-on box end 12pt crows foot, 14mm is the size but 9/16 will work ok. It has to be on the torque wrench at a 90 degree angle to obtain correct torque. You can order direct from the Snap-on website.
Old May 20, 2002 | 08:10 PM
Thanks for the input. I'll pick up one of those crows feet tomorrow. And I appreciate the tip on retorqueing the cylinder after it's warmed up.
Old May 20, 2002 | 09:39 PM
Ronnnnn's Avatar
Go to Dennis Kirk and check out this part number. #28729
It works great.
Old May 20, 2002 | 11:51 PM
Thanks for the # Ronnnnn.
Dewhound
Apr 20, 2017 02:25 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
snowolson
Aug 31, 2015 03:51 PM
