P650 oil light ???
Old Jun 11, 2002 | 12:10 AM
cc1999's Avatar
I have noticed my oil light comes on every time I ride though 10" of water or more I am pretty sure the bike is not hot since the cooling fan is not even on yet. Plus when the bike is warm the light never comes on and the fan works fine when it need extra cooling in tight woods riding or drag racing. Does anyone else have this problem????
Old Jun 11, 2002 | 08:24 AM
monteSS's Avatar
No I have not seen this problem. My oil light only comes on when I first start it.
Old Jun 11, 2002 | 09:24 AM
jlpier01's Avatar
I could be wrong, but I thought the oil light was a pressure light, not temp. If it occurs only after water crossings, it is probably just a messed up connection at the sending unit.
Old Jun 11, 2002 | 11:05 AM
northarkie650MUDD's Avatar
the light is indeed a pressure guage. if it is coming on when you go through deep water then you have a short somewhere. heh, 10" of water wont even get my diff's wet [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 11, 2002 | 12:30 PM
trx450's Avatar
Check the boot and the connector at the oil pressure sending unit. It could be grounding out in the water, causing the lite to come on. The sender is right on the frt lower edge of the engine, just below the starter. Poke around in that area, If you have a manual, it will show you a pic of what you are looking for.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
