Trying to get oil in P650 front diff.
Old Jun 14, 2002 | 08:42 PM
2fat4moto's Avatar
HELP!
Changed oil in engine, rear end, & now I am changing oil in front diff. & can't get oil to stay in. It runs right back out.
Old Jun 14, 2002 | 10:00 PM
mastrblastr's Avatar
Be patient grasshopper!! You gotta take your time and it will slowly fill up. Make sure you got a few beers on hand before you start this job. I know it's a pain with that front end gear right there.
Old Jun 14, 2002 | 11:01 PM
nyroc's Avatar
I tipped mine 650 sideways until the amount the manual said it required was in, then put the cap on.
Old Jun 14, 2002 | 11:54 PM
Lurch77's Avatar
<< I tipped mine 650 sideways until the amount the manual said it required was in, then put the cap on. >>
You gotta love the simple answers. [img]i/expressions/face-icon-small-smile.gif[/img] I am doing all my first fluid changes on Monday. So far I have learned 2 tricks for fluid changes from the website.
1. cut up a milk jug to keep your skid plate clean while removing the oil filter
2. tip machine sideways for front diff [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 15, 2002 | 05:29 AM
2fat4moto's Avatar
I got it. I took a very small hose and taped it to a funnel. Stuck the hose all the way into the diff. Then while consuming a few beers, waited patiently as the oil slowly filled. And I do mean SLOWLY! When it was full it let me know by running out. Thanks for everybody's help, especially the part about the beers.
Old Jun 15, 2002 | 12:56 PM
TrailHog's Avatar
It's also good to ride it around a little while to get all the oil and fluids warm before changing, it helps to get all the old oil out and it drains faster.
Old Jun 15, 2002 | 01:15 PM
Wish I was as smart as you Trailhog. I changed mine in March and I didn't warm it up first. After 2 HOURS!!! and approximately 6 beers!!, I finally got all the oil out of the front diff. Don't even get me started on how long it took to fill it.
Old Jun 15, 2002 | 01:31 PM
TrailHog's Avatar
LOL!! If I had 6 beers I couldn't have even seen the quad much less find the oil.
Old Jun 16, 2002 | 02:26 PM
scootdog's Avatar
after six beers, are you sure it was`nt the wifes car you changed the oil on?!!!
Old Jun 17, 2002 | 02:04 AM
northarkie650MUDD's Avatar
i have a long neck funnel that screws onto the oil container...worth its weight in gold....if you have a problem with oil running out of the filter...drain the engine first, i let mine sit for about 30 mins then change the filter, usually have none left in it.
