Scrabler 500 antifreeze
Old Jun 26, 2002 | 05:57 AM
Whitelightning74's Avatar
i have new scrambler about 5 months old and I am starting to notice that it is useing a little antifreeze. It only drops from full just to just below the minimum line about once a week. Is this normal and if not what causes this.
Old Jun 26, 2002 | 08:20 AM
brooks999's Avatar
I have noticed that my Scrambler 500 HO 4x4 does the same thing. I will keep an eye on this thread.
Old Jun 26, 2002 | 10:28 AM
MUDFUN's Avatar
Are you seeing any coolant spots under the machine? If not how often have you used it in since you bought it? It might just still be bleeding the air out of it's cooling system.
Old Jun 26, 2002 | 11:35 AM
Scrmblerman's Avatar
Not sure if I understood your post Whitelightning74. Do you mean it goes from full to minimum level in one week? I have had mine for over a month and it doesn’t seem I have used any coolant in the side reservoir. I am wondering if mine is working correctly?
Old Jun 26, 2002 | 02:05 PM
BarelyLegal's Avatar
There is a tiny hole in the top of the overflow cap to allow it to drop a little fluid when it gets hot or whatever. It's normal. Look at that red cap and riight around it. Do not block this off.
Old Jun 29, 2002 | 04:33 AM
yes it seems to fall from full to minimum in a week or so which is not alot, I have notice no leaks and its been run a good bit since being new. I think the hole in the cap may be the ansew simce temps around here are in the 90's it probaly evaporating.
Old Jul 1, 2002 | 10:50 PM
motorman's Avatar
my 400 xplorer does the same thing but never goes below the add mark so i just leave it there.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Psycho
Mar 30, 2003 08:11 PM
BigD500ho
Mar 30, 2003 01:10 AM
