Scrabler 500 antifreeze
i have new scrambler about 5 months old and I am starting to notice that it is useing a little antifreeze. It only drops from full just to just below the minimum line about once a week. Is this normal and if not what causes this.
Not sure if I understood your post Whitelightning74. Do you mean it goes from full to minimum level in one week? I have had mine for over a month and it doesn’t seem I have used any coolant in the side reservoir. I am wondering if mine is working correctly?
yes it seems to fall from full to minimum in a week or so which is not alot, I have notice no leaks and its been run a good bit since being new. I think the hole in the cap may be the ansew simce temps around here are in the 90's it probaly evaporating.
YamahaBoi
Jun 22, 2015 08:11 AM
