P 650 clicking noises
I know this has probably been discussed, but I can't find a post. I recently bought a p 650 and it makes a "click" noise when I give it gas , when I let off the gas, and when I go ever a log or big bump. It is alot more noticeable at low speeds and in low range. I've never owned a quad with belt drive transmission and just wonder if it is normal. The dealer told me it was normal, but I would like to hear from you guys. Any info will be appreciated.
The slight click is just gear play in the trans.
If it ever ratchets slowing down in low range, the shifter needs adjusting. A shifter adjustment is really the most common thing that 650's need. After that, belt adjustments.
Ditto what nyroc said. Normal sounds, you'll get used to it. You won't notice it after a few hours in the saddle. I had a time getting used to all the weird little noises in mine, now I only notice if they AREN'T there! Enjoy the ride.
BTW--- Welcome to the "Connection" !!!!!!!
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
