P 650 clicking noises
Old Jul 10, 2002 | 03:38 PM
nightrunner's Avatar
I know this has probably been discussed, but I can't find a post. I recently bought a p 650 and it makes a "click" noise when I give it gas , when I let off the gas, and when I go ever a log or big bump. It is alot more noticeable at low speeds and in low range. I've never owned a quad with belt drive transmission and just wonder if it is normal. The dealer told me it was normal, but I would like to hear from you guys. Any info will be appreciated.
Old Jul 10, 2002 | 03:44 PM
nyroc's Avatar
The slight click is just gear play in the trans.
If it ever ratchets slowing down in low range, the shifter needs adjusting. A shifter adjustment is really the most common thing that 650's need. After that, belt adjustments.
Old Jul 11, 2002 | 08:37 AM
trx450's Avatar
Ditto what nyroc said. Normal sounds, you'll get used to it. You won't notice it after a few hours in the saddle. I had a time getting used to all the weird little noises in mine, now I only notice if they AREN'T there! Enjoy the ride.
BTW--- Welcome to the "Connection" !!!!!!!
Old Jul 11, 2002 | 11:07 AM
Thanks for the info.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
