Baseline jetting 400 scrambler
Old Jul 13, 2002 | 09:01 PM
ox's Avatar
ox
I bought a baskets case machine last spring and put it together. New case and piston. It had a DG can on it. Pipe seems stock. This thing gets terrible milage. Aboot 10 at best. But it also seems to run bad too. I am in process of checking the timing too, but I would like to know what the baseline for this machine is. I am now running stock can.
I have a big manual for this thing, and it tells me stuff like if it gets colder put in a richer jet and etc. Nowhere does it tell me what baseline is.
Also, it might not be a bad idea to check to see what has been done to the clutch too. What are stock weights and ramps? Spring?
I have heard on here last yr that the 400's should get aboot 17 mpg? It has enough power to pull the front end usually, but it still feels like it comes up short for a 400.
Thanks for any help fellas!
Old Jul 13, 2002 | 10:02 PM
scramblered's Avatar
if i remember the main must be 240 with stock pipe and can,cannot tell the pilot and needle setting toughts.
i'm not sure but stock the 400 come with 58 g of weights,if you're going to keep the machine stock i suggest a cheap but good clutch kit from EPI.
Old Jul 13, 2002 | 10:49 PM
MattDewalt's Avatar
I just removed all my stock stuff today. Main jet 230, pilot jet 35, 1.5 turns out on air screw, white primary spring, red secondary spring, S55 weights. At least that's what my 99 Scrambler 400 4x4 had in it from stock.
Old Jul 14, 2002 | 01:07 PM
ox's Avatar
ox
Mine is a 99 too. Thanks!!!
Old Jul 14, 2002 | 01:08 PM
ox's Avatar
ox
ox's Avatar
ox
Old Jul 14, 2002 | 01:09 PM
ox's Avatar
ox
Old Jul 14, 2002 | 10:07 PM
maximus's Avatar
i went throu the same thing and it was the choke cable was not in far enough. it ran bad and got terrible gas mileage. something like 5 miles five galons. stock settings are 30 piolt jet 200 main,1.5 turns out on air screw, needle in middle postion.
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
