Grizz 660 air filter problem
Old Jul 15, 2002 | 09:20 AM
vugger's Avatar
Yesterday while riding my Grizz, it started to idle at half throttle. I was going maybe 50mph and let off of the throttle and it kept going on its own at about 30mph. I shut it off to see what was going on. I opened up my air box to check it out and I realized that part of that filter that acts as a gasket between the air box and air filter was gone! I couldn't find it anywhere, and I am sure that it was sucked into the engine. Finally after playing with the carb a little it released and then the Grizz started to idle o.k. I rode it the rest of the day without any problems. Is there anything that I should do? Does something like this cause any damage to the piston or cylinder? Any help would be appreciated.
Thanks
Old Jul 15, 2002 | 09:18 PM
vugger's Avatar
any suggestions?
Old Jul 16, 2002 | 11:54 AM
Frogman28's Avatar
If sand or dirt will screw up an engine, i am SURE that the foamrubber gasket that seals the airfiliter will! Did you find it? It couldnt have went to far.... Have you taken the carb apart? I dont know how that thing would make it to the piston....unless the gas disolved it. If that is even possibe, i would say that you better start cleaning your fuel supply out.
There has to be someone on this FORUM with more info than me....
Jonathan
lightninboy
May 16, 2021 09:52 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
toonces
Jul 11, 2015 12:01 PM
cSchwartz
Jul 9, 2015 02:43 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
