flashing lights
Old Jul 15, 2002 | 03:51 PM
Cannitor's Avatar
due to 2 broken ribs i havent been able to ride for about 5 weeks and my raptor sat idle...anyways...started it yesterday and everythings ok except
the brakelight flashes on and off...not the taillight,just the brakelights
has anybody had this happen?any solutions or thoughts?...thanks
Old Jul 15, 2002 | 04:00 PM
RaptorRcR's Avatar
Look on your brake lever. When you pull the lever in...you will see a button coming out of a switch at the pivot point. Sometimes my switch wiggles loose and will flash or stay on. Make sure you push the switch towards your brake lever and see if that fixes it. If it does, there is a clip under the lever where the switch mounts that you may have to bend out a little bit.
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
panicmanic
Sep 28, 2015 12:59 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
