Grizzly 600 Sprag Clutch
Old Jul 17, 2002 | 08:18 PM
wgr's Avatar
wgr
I have a noise at idle on a 600 Grizzly,when you remove the belt the noise goes away until you put pressure on the primary clutch.The belt is pulling on the clutch causing the noise.There is slight play in the bearing is this alone causing the sprag cltch to make the noise or do sprag clutchs develop wear.thankyou.
Old Jul 19, 2002 | 05:02 PM
RapTech's Avatar
Sounds like the one way bearing (sprag) is dragging or one of the springs on the centrifigal clutch is broken. Dealer time.
Pgbama11
Jan 16, 2016 08:19 AM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Pgbama11
Sep 10, 2015 08:20 AM
cdstang
Aug 31, 2015 07:52 AM
