Grizzly 600 Sprag Clutch
I have a noise at idle on a 600 Grizzly,when you remove the belt the noise goes away until you put pressure on the primary clutch.The belt is pulling on the clutch causing the noise.There is slight play in the bearing is this alone causing the sprag cltch to make the noise or do sprag clutchs develop wear.thankyou.
TLC
Utility ATVs
09-16-2015 01:41 PM
cdstang
08-31-2015 07:52 AM
