Warrior.....Need Help.....
Old Jul 18, 2002 | 08:37 PM
QuadZmoto's Avatar
Warrior won't start! Not getting any spark. Tried 2 new plugs... nothing. Checked everything else out. Could it be the magnetto? Any help would be appreciated.
thanks
Old Jul 18, 2002 | 08:53 PM
warrior007's Avatar
I figure since you tried 2 new plugs you didnt see if they were actually firing.
Ground the plug on the motor, let it dangle and touch the case of the motor, crank it over and see if it sparks. If you hold on to it you may get knocked on your butt. If still no spark it could be the coil, the pickup or the cdi.... If there is spark you have a fuel or compression problem.
Old Jul 18, 2002 | 09:00 PM
QuadZmoto's Avatar
I checked for spark.... nothing.What is the pick up coil?
Thanks QuadZmoto
Old Jul 18, 2002 | 09:33 PM
QuadZmoto's Avatar
You were right, it was the pick up coil, it was loose.
thanks alot....
jpike01
1) Engine problems..
Dec 19, 2010 06:42 PM
soapy
Jul 10, 2010 11:17 AM
Hondaboy007
Feb 16, 2010 11:26 AM
island hunter
Aug 2, 2009 05:48 AM
ATVROOKIE55
Jan 29, 2009 07:22 PM
