Carb mounted filter?
Old Jul 21, 2002 | 01:15 AM
BENCHSEAT's Avatar
Has anyone heard of or seen a carb mounted filter that eliminates the air box totally? One of the guys I ride with has a DS and he got a carb mounted filter from K and N. I was just wondering if anybody has come up with that kind of mod. His DS flowed a lot better than with a modded air box.
Old Jul 21, 2002 | 02:32 AM
Ward660R's Avatar
No one makes a filter that can go on the two carbs of the Raptor because they are so close together. I don't run an air box but the filters are not clamped on the carbs.
Old Jul 22, 2002 | 01:24 PM
BlueLeader's Avatar
here is my setup filters
Trinity 686, stock headpipes, HMF slip-on, 180/185 mains, 25 pilots, needle in 4th slot.
For those of you with no airbox please post your carb settings. Thanks
Old Jul 22, 2002 | 06:57 PM
Ward660R's Avatar
I don't have any pictures of my set-up, but I need them, and I can't explain it very well but I'll give it a shot. I have two K&Ns clamped onto the Pro Desgin flange for my foam filter. I cut ALL of the air box off from around the flange so I could still use the pins for support without making something new. I used cotter pins to keep the plastic pins on the air box from sliding back through. I run 170 and 175 mains with 27.5 pilots and the needles are in the fourth clip from the top. I can't remember the screw settings off hand but I think that it is 2.75 and 3.0.
BTW thanks Blue Leader for the help many months ago. You are the one that gave me this idea after the filters I bought wouldn't fit on the carbs.
Old Jul 22, 2002 | 08:50 PM
BENCHSEAT's Avatar
Blue Leader did you make that bracket to mount the filters? What part number are the filters?
Old Jul 23, 2002 | 03:39 PM
BlueLeader's Avatar
I used a scrap piece of angle aluminum and zip tied the filters to it for support. I can't remember the part number. They are 2.5" ID x 5" diameter x 7" long. I will check and report back.
lightninboy
May 16, 2021 09:52 PM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
