raptor mixture screws
The mixture screws will be set different for each Rap, especially from different dealers. Each dealer will set them up differently and you can expect to get a different aswer on the air/fuel mixture screws when asking a dealer what the initial settings should be.
As far as how far you can go before they fall out, why on earth would you want to know that? If you have to go more then 4 complete turns out, you have more problems then you think.
Even the shop manual doesn't tell exactly where to set the pilot screws. It merely say to set to the original settings after re-installing the carbs. The nominal setting on most quads is 1 1/2 to 2 turns out with adjustment from there. Pilot screw adjustment is only a fine tune adjustment on a correctly jetted engine anyway.
When I was,[still are, fine tuning], jetting my raptor to coincide with the air box mods I made, I called atleast 8 different dealers and got 8 different answers. I also have a shop manual and it says cabrb1[left]1 turn and carb2[right] .9. I got answers all the way up to 3and 3 1/2. Look at the post air fewl screws, or something like that, in here. It was only posted a few days ago. It gives the best possible way to adj. those things correctly. You can do it by ear but a vacuum gauge is the way to go. The most common answer i got was 3on the left and 2 on the right.
2001 raptor, ct pipe, pro-flow foam, air box mods,
tag x-5, razrs, soon to be installed 12 tooth front.
yea been ridin my new 2003 raptor for a little eover a month now i change da oil and grease it myself but the dealership wants 70 buckz for maintainence and im not down with that!!!! i kno how ta do everything but whut should i do about getting my valves adjusted!!!!!not familiar with workin on raptors and the other stuff!!!!
Oct 10, 2015 10:20 AM
