raptor mixture screws
Old Jul 23, 2002 | 09:20 PM
wheeliedude's Avatar
what are the mixture screws set at on a stock raptor? How far can they be turned out before they come out? thanks.
Old Jul 23, 2002 | 09:26 PM
swytak's Avatar
The mixture screws will be set different for each Rap, especially from different dealers. Each dealer will set them up differently and you can expect to get a different aswer on the air/fuel mixture screws when asking a dealer what the initial settings should be.
As far as how far you can go before they fall out, why on earth would you want to know that? If you have to go more then 4 complete turns out, you have more problems then you think.
Old Jul 23, 2002 | 09:53 PM
I didn't mean it to sound like that, but how far out and still have them working. I'm doing some intake+exhaust mods, and am close to sea level, so I figure I would need to turn them out some.
Old Jul 23, 2002 | 10:16 PM
hot_shoe_cv's Avatar
Even the shop manual doesn't tell exactly where to set the pilot screws. It merely say to set to the original settings after re-installing the carbs. The nominal setting on most quads is 1 1/2 to 2 turns out with adjustment from there. Pilot screw adjustment is only a fine tune adjustment on a correctly jetted engine anyway.
Old Jul 24, 2002 | 12:42 AM
spacollie's Avatar
When I was,[still are, fine tuning], jetting my raptor to coincide with the air box mods I made, I called atleast 8 different dealers and got 8 different answers. I also have a shop manual and it says cabrb1[left]1 turn and carb2[right] .9. I got answers all the way up to 3and 3 1/2. Look at the post air fewl screws, or something like that, in here. It was only posted a few days ago. It gives the best possible way to adj. those things correctly. You can do it by ear but a vacuum gauge is the way to go. The most common answer i got was 3on the left and 2 on the right.
2001 raptor, ct pipe, pro-flow foam, air box mods,
tag x-5, razrs, soon to be installed 12 tooth front.
Old Jul 24, 2002 | 12:47 AM
spacollie's Avatar
That post is air fuwl screws- Whats your final answer. Really good info.
Old Jul 24, 2002 | 10:28 AM
thanks a lot fellas[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 24, 2002 | 11:33 AM
garyc660R's Avatar
settings will vary from Rap to Rap. Tune it properly with a vacuum guage....mine liked (yard ornament now) 1 less turn on the left side.
Old Jul 25, 2002 | 02:28 AM
aluminumarmy's Avatar
yea been ridin my new 2003 raptor for a little eover a month now i change da oil and grease it myself but the dealership wants 70 buckz for maintainence and im not down with that!!!! i kno how ta do everything but whut should i do about getting my valves adjusted!!!!!not familiar with workin on raptors and the other stuff!!!!
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
black_thunder
Sep 22, 2015 07:59 PM
