Will a Dynojet jet work with a stock needle?
Old Jul 30, 2002 | 11:54 AM
Rockey's Avatar
Ot do you have to have a dynojet needle? Let me know before i waste my money.
Old Jul 30, 2002 | 11:58 AM
DSaholic's Avatar
The dyno jet kit is designed to work with the needle and the jets not one or the other. I have heard that it actually will hinder performance if you use the jets with the stock needle of the stock jets and the dyno jet needle. You can get the whole kit from rockymountainatv.com for about 45 bucks.
Old Jul 31, 2002 | 08:43 PM
Hightower's Avatar
DSaholic is right, the dynojet jets may not flow the same with the stock needle as they do with the Dynojet needle. the Dynojet needle is the big gain anyway, it really improves throttle response on a stock motor.
Knowing you are in process of creating more air flow, because you had prior posts of asking if Mikuni had anything bigger than a 200 main for the stock carb, I should tell you that the biggest main Dynojet makes is 210, and it actually doesn't flow any more fuel than the mikuni 200. Dynojet numbers represent the diameter of the hole, as opposed to flow rate like Mikuni #'s. Check out the chart below, it may help...
Dynojet/Mikuni compare chart
Old Jul 31, 2002 | 08:58 PM
Rockey's Avatar
I got my Mikuni 200 jet in today. This thing absolutely rocks! I cant believe the midrange gains. The sparkplug is still gray on the electode and I feel it is still too lean. I will have to step up to a bigger carb soon, especially when the weather starts to cool off! I took the DS to Haspin today and am very satisfied with the gains it has made. I am anxious to see what is going to run on Friday.
Old Aug 1, 2002 | 03:48 PM
Hightower's Avatar
Sweet Rockey!
By the way, where and how much was your Uni filter? I use Uni on my 350X, and want it for the DS now too becasue the Badlands is too dusty for the K&N.
Old Aug 1, 2002 | 05:03 PM
01ds650's Avatar
I may need to try a Mikuni 200. I ran a Dynojet 210 with the lid off & believe could have went richer than that. It ran OK.
Old Aug 1, 2002 | 06:42 PM
Hightower's Avatar
Andrew - in case you might've missed the other thread Rockey had - Rockey just did a port job, and that's why he's jetting up so big.
Old Aug 1, 2002 | 06:46 PM
Rockey's Avatar
Chris, I bought my UNI at a local motorcycle shop. It waas actually for a 250R but I made it work with my airbox. I believe rocky mountain ATV sells them.
Old Aug 2, 2002 | 04:26 PM
01ds650's Avatar
Hightower,
yes I know. I was surprised too that I wasn't bogging out. I asked NewDSlover 2 weeks ago if my "testing" seemed normal. Doesn't seem right to me but it ran strong. Who knows, If I ride slow tight trails for an hour then maybe it would load up. I'm puzzled, it's seems lately when jetting the rules don't apply to my quad.
Old Aug 2, 2002 | 04:31 PM
01ds650's Avatar
As far as a 250R filter working on a DS, when I bought an outerwears filter it said "250R, Banshee, DS" Must all be somewhat alike.
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
