bog or burned down
Old Jul 31, 2002 | 07:12 PM
scramblered's Avatar
just some impressions to you all when modded your 2 stroke scrambler,when using filtercharger (NO AIRBOX),keep an eye on this,the carb is twisting/shaking so bad that it can cause you some jetting problem and by the end a lean mixture resulting to a engine failure,find out with the time using different carbs,air leak/bad faoming of the carb are pretty possible when those motors are boosted up,tight your boot carb and filter properly...
Old Jul 31, 2002 | 11:08 PM
but tonight,problem is solved,i got a nice blast ride with using a KICK *** air filter,more air flow than the k&n for sure (more torque,more top end power),those filter are made for snowmobile applications and uses,it is shorter and the "vibrations" problem seem end,looking to get an outerwear pre-filter to fit on it soon.
Old Aug 1, 2002 | 04:46 PM
i really tell you guys,try it out one of those KICK *** air filter on yours modded 400,torque gains for sure with LESS $$$.
Old Aug 1, 2002 | 05:17 PM
CED's Avatar
CED
I'm interested.Where can i get one.
Old Aug 1, 2002 | 06:50 PM
i got them from PSI PERFORMANCE,
http://WWW.PSIperformance.com/
Old Aug 1, 2002 | 06:58 PM
Highjumper1's Avatar
Do you think with the airbox gone on a 400sport 2x4 that the carb. can vibrate enough to cause a rich load and cut out sometimes, no mods yet.
Old Aug 2, 2002 | 12:10 AM
Bubba297's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]Highjumper, if you have a problem with it, it will probably be what I ran across. The fuel might foam in the carb and cause some mid-rpm hangups. I havent had any rich problems,though. I run the 4" open element right on the back of the carb. Bubba
Old Aug 2, 2002 | 12:29 AM
sevy's Avatar
Thanks for the info. I was thinking about getting a K&N but i'll check out the one from PSI first
Old Aug 2, 2002 | 12:06 PM
try KICK *** AIR FILTER,when time come to get a new filter instead of k&n,you shouldn't disapointed about the power boost...
with the stock carb with no mods,i see no problem running no airbox,it is when bigger carb is using the engine/boot/carb vibrate a lot more.
Old Aug 2, 2002 | 12:07 PM
BUT! keep an eye on the spark plug color,very important.
