Xplorer 400 4x4 problems PLEASE HELP!!
Old Aug 5, 2002 | 09:23 PM
Buckmaster128's Avatar
I have a 1006 Xplorer 400 4x4. The 4wd wont work. It will work SOMETIMES in reverse but not when u need it. It has only worked foreward oncer since I have qwned it. We have 6 volts coming 2 the AWD switch but I don't know if the hubs are 6 volt or 12 volt. If somebody could give me this information if would be greatly appreaciated. I can feed 12 volts directily 2 the hubs and put a switch 2 turn it off or on if they are 12 volt hubs. I also have heard that the battery can effect it. I am going to put a new battery on it and see what happens but if u have ANY advice on what the problem might be please HELP!!
Old Aug 5, 2002 | 09:25 PM
That 1006 is supposed to be 1996******
Old Aug 5, 2002 | 09:48 PM
ZoomZoom's Avatar
Not sure about the voltage thing. I had a similar problem, sometimes the AWD light would come on when I wiggled the shift selector.
What I found was that after taking the shifter box open & inspecting the switch, the contacts where dirty & needed reshaping back to it's original shapes. Haven't had a problem since.
Hope this helps.
Old Aug 5, 2002 | 10:23 PM
Farmr123's Avatar
The hubs should be getting 12 volts. If they aren't, trace the wire back to where the voltage drops. Most likely, there will be a dirty switch, bad connector, or such.
Also, don't forget the obvious. Check the battery and connections, be sure thay are clean, too.
Farmr
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
cornermike
Jul 8, 2015 11:44 PM
