Xplorer 400 4x4 problems PLEASE HELP!!
I have a 1006 Xplorer 400 4x4. The 4wd wont work. It will work SOMETIMES in reverse but not when u need it. It has only worked foreward oncer since I have qwned it. We have 6 volts coming 2 the AWD switch but I don't know if the hubs are 6 volt or 12 volt. If somebody could give me this information if would be greatly appreaciated. I can feed 12 volts directily 2 the hubs and put a switch 2 turn it off or on if they are 12 volt hubs. I also have heard that the battery can effect it. I am going to put a new battery on it and see what happens but if u have ANY advice on what the problem might be please HELP!!
Not sure about the voltage thing. I had a similar problem, sometimes the AWD light would come on when I wiggled the shift selector.
What I found was that after taking the shifter box open & inspecting the switch, the contacts where dirty & needed reshaping back to it's original shapes. Haven't had a problem since.
Hope this helps.
Hope this helps.
The hubs should be getting 12 volts. If they aren't, trace the wire back to where the voltage drops. Most likely, there will be a dirty switch, bad connector, or such.
Also, don't forget the obvious. Check the battery and connections, be sure thay are clean, too.
Farmr
Farmr
