*Mojave Valve Adjustment (need help quick!!)*
Old Aug 9, 2002 | 11:55 PM
MOJAVE02's Avatar
i need to know detailed step to step instructions on how to adjust the valves on the mojave. What tools do i need? How are they adjusted? What are the valve adjusment specs? and also anymore of the info or tips anybody can give me. please help me.
Old Aug 10, 2002 | 12:54 PM
Chris142's Avatar
With engine cold.
(1) remove all plastic
(2) Remove gas tank
(3) remove the ignition coil
(4)remove the valve cover
(5)remove the two plugs directly above the shifter.
(6)using a 17mm socket and a flashlight line up the "t" on the magneto with the line in the top of the uppermost hole(where you took the plug out of).
(7)theres two (0) looking things on the cam gears,they must be opposite(the one on the exhaust cam facing towards the front of the bike,the one on the intake must be facing the rear of the bike)and they must be level with the top of the head.If not repeat step six,but turn engine over 360 degrees and try again.
(8)set valves to .008-.010
(9) put bike back together
Old Aug 10, 2002 | 01:00 PM
Chris142's Avatar
Oh, you will need a phillips screwdriver,a smaller blade screwdriver,a 10mm socket and rachet with a 6 inch extension.A 10mm wrench,17mm socket and a set of feeler guages.
Old Aug 10, 2002 | 01:02 PM
Chris142's Avatar
And a pretty large screwdriver to get the plugs out of the case.
donintennessee
Jan 8, 2021 12:40 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
hondarider1234
Jul 21, 2015 11:53 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
MNatv89
Jul 7, 2015 11:36 AM
