2 ?'s about warn winch and slime
Old Aug 19, 2002 | 07:41 PM
02bigbear4x400's Avatar
Hi I was looking at the warn manual briefly and it says do not submerge under water...What happenns if it goes under water?? Also about how many ounces of slime should I use for each of ym tires on my big bear?? its got 25 inch tires
Old Aug 19, 2002 | 07:53 PM
warrior620's Avatar
Well if you submerge it under wate and the engine dies you just ingested water and that is NOT a good thing. On the slime a full 32 oz. bottle per tire
Old Aug 19, 2002 | 08:30 PM
well I did just that with my winch today and I am glad the winch still puleld my atv out of that muck thankg god! and why the heck does slime cost so much! I got 3 8 0z bottles for $18! I think i will just carry fix a flat with me for now on
Old Aug 20, 2002 | 12:10 AM
NorthernEdge's Avatar
My winch has spent a fair amount of time under water an no problems to date!
Old Aug 20, 2002 | 12:52 AM
Frogman28's Avatar
The warn manual posts not to put the winch under water for liability reasons. I can tell you from experience that my winch spends most of its riding time UNDER water and has never failed me. That is what the winch is for (at least for me). I also use this winch to lift a plow and pull tree's out of the woods. Been a great winch so far. Only thing that i dont like is that you MUST re-spool the wire after every couple of uses or it seems to "rat-nest" and get tangled up. I wish there was an auto-guide that would spool the wire back into place [img]i/expressions/face-icon-small-sad.gif[/img]
Jonathan
Old Aug 20, 2002 | 12:00 PM
I know what you mean about the "rat nest" thing about the winch wire..it definatly does suck because it happened to me when i pulled my big bear out the the muck yesterday and the winch was all the way underwater. Oh what is the solenoid thing suppose to do anyways??? Also why the heck is slime so expensive! I got 3 8 oz bottles for $18 and thats not enough for two tires
Old Aug 20, 2002 | 12:52 PM
peregrine's Avatar
A solenoid is actually a relay if it is switching electrical current. It has large surface contacts to handle the current that the winch will draw. When you either turn your bike key on, or your winch switch on, depending how it is wired, the solenoid pulls the contacts together and allows current to flow to the direction switch. Basically it allows you to switch large amounts of current with small guage wire and switches.
Old Aug 20, 2002 | 09:25 PM
foneguy's Avatar
hey frogman, im a little new to the plowing, ill be using my winch with a roller fairlead, do you use the snachblock on the blade or dony bother? ,
and 02bigbear, i used 1 16 oz botle on each tire
Old Aug 21, 2002 | 02:11 AM
Frogman28's Avatar
When i say snatchblock...i just mean for pulling your quad out of the mud, pulling trees, directing trees that are being cut, etc. I dont use the "block" on the plow.
The plow has a hook where ther winch cable hook will attach. It is hard on the fairlead and the cable using the winch. Plus, the cable will rat-nest on you if your not careful. I would recommend using just a "plow lifter", power or manual.
Sorry if i confused you at all.
Jonathan
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
