Do you use your trailtech lights AND stocks lights ???
Old Aug 23, 2002 | 10:19 AM
MichaelAZ's Avatar
Do you use your trailtech lights AND stocks lights ??? I was curious if it is possible to run the stockers of the low beam and the trailtechs off the high beam ?? Can you run both at once with the stock stator ??? TIA
Michael
Old Aug 23, 2002 | 01:41 PM
redrocker's Avatar
Yes I have mine wired so low beam
is just the stock low beam and high
beam is the trailtechs and the stock
high beam so you get 170 watts of light
been running it like that for over a yr
works great
Old Aug 23, 2002 | 03:21 PM
THEMOOSE's Avatar
I've been running mine off a seperate switch because I didn't know if the stock light switch could handle the extra amps.
redrocker what voltage lights are your trail techs?
I run 2~50 watt trail techs & I think I'll go ahead & hook them to the stock light switch.
It'll make for a cleaner hook up & I won't burn my hand when I use my remote switch!!
Old Aug 23, 2002 | 03:40 PM
RaptorRyan's Avatar
I removed the light's in the stock location and replaced them with 75w Ricky Stator light's. This set up put's out an excellent amount of light and it plugs into your factory harness.
Old Aug 23, 2002 | 03:50 PM
redrocker's Avatar
Moose
I'm running 2 50 watt lights also
the stock switch works great
hope that helps
Old Aug 23, 2002 | 10:51 PM
THEMOOSE's Avatar
I'm gona hook up mine that way then, I can get rid of a lot of excess wiring that way!!
Thanks!
slowgsxr97
Mar 18, 2022 03:40 AM
Ean
Aug 28, 2015 09:39 AM
Huntingdeer
Aug 23, 2015 12:06 AM
erntee61
Aug 9, 2015 02:54 PM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
