Lift
Old Sep 4, 2002 | 11:04 AM
edstr13's Avatar
What do you P650 guys think about lifting it, Have any of you done it, why or why not, do you like it if you have?
Old Sep 4, 2002 | 12:28 PM
monteSS's Avatar
I wouldn't do mine because of the extra wear on the joints and drive train.
Old Sep 4, 2002 | 12:34 PM
nyroc's Avatar
One reason I got a 650 because of the lower center of gravity. Lifting is just not my cup of tea. I even feel a little more tippy with tall tires, when I am ridind off camber. I sometimes ride on such serious slopes that I stand both feet on the edge of one floorboard, and hang body as far as possible on uphill side. Works a lot better on right side of quad than left.
Old Sep 4, 2002 | 10:59 PM
vlucdog's Avatar
lets see 3 guys lifting 200 pounds each. yea you could do it
02 400ex
00 trailboss
99 lakota
Old Sep 4, 2002 | 11:24 PM
mastrblastr's Avatar
I made my own 1 1/4 inch lift kit. I also made some spacers to put in my front shocks to increase the front spring preload and I maxed out my rear shock preload. Why? Cause I weigh damn near 300 lbs. and I bottomed out my front shocks more than once. After fixing up all my shocks, I don't bottom out no more. The only reason I put a lift in it is because I ride over a lot of trees and rocks and the extra clearance helps quite a bit. That and the fact that with the 26 inch 589s on there, it looks WWWAAAAAAYYYY cool!!!!!
Old Sep 5, 2002 | 01:20 AM
cammoman's Avatar
It depends what you want to do with it? I like mine because we have bad winters and it provides better clearance. Also my dealer said when I put my snow plow on it would really sag in the front, so the $150 lift was cheaper than putting on new shocks. The only thing I don't like is off cambers it tends to want to roll, but that could be from the stock Dunflop tires. I am waiting to hear if anyone likes the new Radial Outlaws befor they get replaced.
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
