synthetic oil in rubicon
Old Sep 11, 2002 | 05:59 PM
patpath's Avatar
Hi guys, any comments or advise about using synthetic oil in a Rubicon? I own one and I am curious to know if it could be a good choice.
Thanks
Old Sep 11, 2002 | 07:17 PM
ScramblerXcitement's Avatar
Pat, I use regular motor oil, no problems.
Old Sep 11, 2002 | 10:04 PM
91Octane's Avatar
I would not recommend you use synthetic oil in your Rubicon. It is not proven that it will perform properly with the transmission. I wouldn't take the risk.
Old Sep 12, 2002 | 12:04 PM
YZGUY's Avatar
Why not use a natural/synthetic blend, and get the best of both worlds???? I would pick Hondas top of the line oil with moly (can't remember the name, but it comes in a silver bottle). Oil is no place to try and save money, or cut corners.
Old Sep 12, 2002 | 12:22 PM
Harw's Avatar
You can use the Amsoil synthetic 10W-40 Motorcycle oil with no problem. It will work with a wet clutch unlike the automotive synthetic oils that will not work with a wet clutch. Your quad will run around 25 to 30 deg. cooler. You should pay around $5.75 a qt..
Old Sep 12, 2002 | 02:28 PM
JRM's Avatar
JRM
i have been useing the amsoil 10W40 motercycle oil for a year now in my rubi.... i love it! No problems with the hondamatic's pressure affecting snythinic either.
Old Sep 13, 2002 | 06:04 AM
sandrews46's Avatar
I use Mobil 1 MX4T which is a fully synthetic in mine. This oil doesn't have the friction modifiers in it like the regular Mobil 1. If you use oil with the moly or friction modifiers in it you will cause the clutch to slip.
Old Sep 13, 2002 | 01:23 PM
action450s's Avatar
I always use OPTI 4 synthetic in my 450s, expensive but worth it. It is the oil Honda uses from the factory. I have a 1000w honda generator that is 14 years old and still runs like new with regular maintenance including OPTI 4.
shimanok2
Jan 29, 2016 07:37 PM
Alex G.
Sep 19, 2015 06:34 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
