problems with belt and front end on the 650
Old Sep 15, 2002 | 02:17 AM
2002scrambler's Avatar
i had a 650 and it lasted me 4 months before the belt burned up in it and then after paying 125 dollars for it the front end started to making poping noises and when u put it in low lockit would sound like metal against metal grinding noise so i got rid of it
2002 polaris 500 scrambler
Old Sep 15, 2002 | 08:38 AM
trx450's Avatar
How many miles on the belt? Are you using low range in the tight, technical stuff? Any slow stuff(under 15mph)You should use the low range. You mite also want to install the EPI "black spring" on the driven pulley.
The popping MAY be loose frt. whl. brng. outer race in the knuckle. The 360's had this problem. It was solved, by the dealer, by setting the outer brng. race with LockTite stud and brng. mount.
Hope this helps. ALSO-- See my post about the Oct 5th P-650 ride at H/M, Bear Wallow trailhead.
OOPS--- Just realized you got rid of it. Sorry about your bad experience with the bike, I love mine. You are STILL welcome to show up on Oct 5th, ALL BRANDS welcomed.
Old Sep 15, 2002 | 07:10 PM
Kawi650's Avatar
2002 my brother had a 99 scrambler and it cost him 18000 can for 18 months. the poping noises is because you switch 2 to 4 while spinning.
WilliamBos
Sep 30, 2015 08:08 AM
scaldwellk
Jun 19, 2015 05:08 PM
blaze_master
May 26, 2015 11:18 AM
